Results 1 to 7 of 7
Thread: zenith carb adjustments?
    Mar 2005
    I have a 1970 911T with the original Zenith Carbs and I was wondering
    about how to adjust it. I know there are richness adjustments for each
    barrel and a de-accelleration circuit that needs adjustment but are there
    any other adjustments that need to be made? I have adjusted these as well
    as cleaned the jets but still get some "pops". What have I missed?
    Don
    Triple black 1970 911T Targa
    Red 2006 Cayman S
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
    Mar 2005
    Thanks. Should probably start by balancing airflow as much as possible.
    Last time I did it on PMOs it didn't seem to make
    much difference though. Thanks again.
    Don
    1970 Triple-Black 911T
    2006 Cayman S
    Mar 2016
    Italy
    eaton's suggested link is very good, anyway as you are going with zeniths you should also give a look at
    http://www.suggate.co.uk/zenith/new_site/zenith.htm
    here you can find specific zenith manual and setup instructions
    P.S. you should also describe your pops (thru carbs, thru exhaust, on accel, on decel, at how many RPMs you hear them) for us to help you.... please explain your problem.
    May 2005
    Oroville, CA
    On my 70 USA, When I took the Zeniths apart to clean them, I removed and plugged all of the hoses and related smog stuff. (even the electric gizmo...)
    No more popping....Then increased the mains and readjusted and they ran almost "normal" (like a weber).
    Much better...so much so that I decided to keep them.
    H
    Oct 2013
    Kirkland, Wa
    H,
    I need to do this to my zeniths. Perhaps you can provide specifics or chat on the phone with me sometime.
    with me sometime. Ravi
    Ravi
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    My only suggestion is to be sure the rest of the engine is in good tune...
    Valves adjusted, plugs, wires, cap & rotor clean and timing set.
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
