Results 1 to 9 of 9
Thread: Rear Turn Signal Housings
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    Hello
    Does anybody have a source for the rubber parts used on the rear turn signal housing on a 70 911? The gasket that seals the rear cover, the rubber spacers for the two mounting screws, the two grey pieces that seal off the lense. Also, if somebody has found something that works for the wiring harness grommet that goes in thru the back cover.
    Does somebody make an original grey colored tail light lense seal?
    Rodger@orbitracing.com
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    light housing / wire grommet.
    http://www.kroonwireharnesses.com/po...9-1973-replica
    Mark..
    Apr 2011
    N.Calif., south of SF
    Thanks Mark - great resource
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jul 2014
    Long Island NY
    Anybody ever find out if the black rubber attaching grommets (addressed above) are available.?
    Member sbartmess's Avatar
    Dec 2015
    NW Suburbs of Chicago
    I believe Erik (soterik) at Auto Foreign Services is making grey seals for his horn grilles, perhaps he has them for the lights too?
    Scott Bartmess - Mbr. No. 3344
    65 356C Cab
    67 911 Sunroof
    71 914-6
    18 991.2 GT3 Touring
    Seeking Engine Case No. 911867
    Quote Originally Posted by Jrsully View Post
    How many would you want? I could cast a few for you.
    I cast them directly on early style lighting harnesses when I make those up for people.
    Never thought about casting them separately.
    They were originally cast directly onto the harnesses when originally made. (Better seal)
    Email or PM me if you want some made.
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Our grommets perfectly fit the wire tube and also seal them off perfectly. After so many years the original rubber got hard, but our new ones are a bit more flexible.
    We use them on all our new early front and rear light looms.
    Because its a small part we can ship them cheap with Dutch Post instead of UPS.
    Best from the Netherlands, Gerard.
    International Mechantile makes the gray seals for the front and rear turn signal lenses.$160.00 for the set.Just saw them on the website the other day.
