Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: FS: 901 transmission parts, gears
    Dec 2004
    SE Michigan
    A: $175 shipped conUS--1 set left
    F: $88 shipped conUS--1 MISMATCHED set left
    X: $155 shipped conUS--2 sets left
    Al side cover: $75 shipped conUS--shown in post #11--1 more available
    Clutch release fork for '72 and similar 915 transmissions:
    Last edited by 911scfanatic; 02-05-2018 at 04:43 PM. Reason: update price/quantity
    Bill G.
    EarlyS #718 | RGruppe #437
    Can you post a pic or two of the nose piece....and
    Do you know if it is OK to put an alum. nose piece on a mag case 901
    thanks
    Bruce
    PM sent for X gear and Pair of axle flanges.
    Dec 2004
    SE Michigan
    I have replied to all PMs. FYI, I have the same thread on PP.
    All gears matched set. The second set of F gears are mismatched. So those are $55 shipped...will make a nice lamp perhaps.
    To my eye, gears look fine. There is no pitting or spalling. My rebuilt trans uses gears in the exact same condition with no issues. There are what appear to be fine machining marks because the root of the teeth looks the same. I have tried to show what I mean in the attached picture. Ring and pinions are smooth by comparison...I assume because the are polished from the higher loads?
    Re: axle flanges, to my knowledge there are two 901 varieties: nadella and 6-bolt Lobros. These are the latter.
    Bill G.
    Quote Originally Posted by 911scfanatic View Post
    There was also a 6-bolt Löbro flange in 68 for "simplified" differentials, which did not use a sealing cap.
    Jon B.
    Vista, CA
    Dec 2004
    SE Michigan
    Someone asked about the availability of dog teeth.
    I have good used 2nd-5th dog teeth I'll included for an extra $20/ea for anyone buying gear sets.
    Also have sliders, hubs, and pretty much everything else.
    Bill G.
    May 2009
    Wellington, New Zealand
    Hi,
    I would like the matched "F" second gear set please, will PM you.
    Regards,
    Reuben
    Dec 2004
    SE Michigan
    availability updated
    Bill G.
    Dec 2004
    SE Michigan
    Quantity update and price reduction.
    Bill G.
    I sent you a PM with availability and quote request
