Results 1 to 10 of 19
Thread: Brake calipers experts
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Need some brake experts.
    Shoot only one picture of the brakes before car left to bodyshop.
    I will have to change the yellow Pagid brake pads for TÜV, but I m not sure about the caliper type.
    May somebody help?
    Last edited by dirk07; 11-21-2016 at 12:08 PM. Reason: Correction of autocorrection
    Aug 2009
    SF Bay Area
    I'm not an expert, I'm just an old Auto Dismantler. It is probably a 911SC caliper. It could be a later Carrera caliper, though. Measure the thickness of the spacer between the 2 caliper halves and let me know the measurement. I will tell you for sure what it is. I'm pretty sure that it is a 911SC because you are still using the original brake rotor. A Carrera rotor is thicker but wouldn't show up in your pictrure. There simply isn't enough information in this picture to make a 100% positive ID.
    Jim
    PS: It looks like you are using later (85 to 89) Carrera front struts, but there isn't enough detail in the picture to be sure
    Apr 2016
    Stuttgart, Germany
Size:  109.5 KBName:  IMG_8671.jpg
Size:  133.6 KBName:  IMG_8667.jpg
Size:  116.6 KBHi Jim,
    Thanks. I ll habe to ask the worker in the bodyshop to measure the space.
    Pictures of the later struts👍
    Aug 2009
    SF Bay Area
    Late Carrera front struts with pre 74 911 hubs. Interesting combination!
    Jim
    PS: Still can't positively ID the calipers, though
    Apr 2016
    Stuttgart, Germany
    Jim,
    Suspension and brakes work very well.
    But we have to change brake pads at least to get TÜV and the even harder to get H Kennzeichen.
    Pic of the Pagids.
    Dirk
    Oct 2008
    Burford, ON, Canada
    To properly identify the calipers we need to know the fluid inlet location; first is the M caliper, and second is the A caliper with inlet at the bottom of the V between the mount holes:
    Aug 2009
    SF Bay Area
    Dave
    The fluid inlet is already known. The issue is the thickness of the spacer between the 2 caliper halves. Carrera calipers have a thicker spacer but use thinner pads than a SC. Both use the same pistons and the swept area of the pads is the same. Carrera brake rotors are thicker than SCs, thus the need for a thicker spacer combined with a thinner brake pad.
    Jim
    Apr 2016
    Stuttgart, Germany
    Jim,
    Pictures of one caliber.
    Measurement of the disk thickness is not correct. Should be measured closer to the center where the pads work.
    BR Dirk
Size:  74.6 KBName:  IMG_8768.jpg
Size:  63.1 KBName:  IMG_8772.jpg
Size:  73.3 KBName:  IMG_8767.jpg
    Oct 2008
    Burford, ON, Canada
    So this appears to be the early A caliper with 7mm spacer & 20mm rotor thickness as opposed to the later wide A caliper for the 24mm rotors.
    I agree with Jim, the SC caliper was pretty much a given; my clue was the conical heads on the screws. However I always like to confirm the fluid inlet. The spacers between the caliper halves do vary on the many caliper versions, so they are also very important to verify.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Dirk,
    I do not get your problems with TUEV.
    Elaborate, please...
    best regards
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
