Guys, I have had 3 different Porsche mechanics try to figure this problem out.
My car is a 69T with a 2.4T (rebuilt Supertec S spec motor). The car runs fantastic and all electricals seem to work - except the tachometer...
The problem with the tachometer is that it reads normal at idle between 900-1,000. But as soon as I accelerate, the needle jumps up and reads 2-3 times the actual correct number. I did some reading and found out that the 1969 cars used a ballast resistor which dampened the impulse reading to the tachometer. Knowing this I tried initially to source a ballast resistor. But because these are hard to find, and even harder to find a good one in working condition, I had my original tachometer simply rebuilt with an internal ballast resistor (same as what the 1970 and later cars used for their tachometers). Despite this, the tacho still shows the correct idle, but 2-3 times correct rev number above 2,000 revs????
Strange details: If I keep one foot on the accelerator pedal above at any higher rev reading, and I press the brake pedal, the rev number drops down to the correct number. Similarly, if the engine is revving above idle (2,000 plus rev's), and I put on the right blinker, every time the blinker flashes, the rev number drops down to normal and then bounces back up every time the signal flashes. WTF is this???
The mechanic looking at the car now is RUF trained and puzzled. He believes that the problem may have to do with the car (a 69T) not having originally had a CD box , which has been retrofitted to accommodate the 72T motor. Since the wiring for the tachometer is pretty straightforward (only 3 cables run the early tachometers: 1) ground, 2) wire to battery, 3) wire to either the CD Box or the coil), I suggested that he bypass the wiring currently going to the tachometer and simply run a cable directly from the tacho itself to the coil or CD Box, the battery cable straight to the battery, and the ground directly to the car's metal. He is going to try this tomorrow.
Anyone ever heard of this problem or experienced it themselves? Why would a tachometer read normal at idle, 2-3 times the correct number above idle? The more time this guy spends trouble shooting, the higher my bill goes. ;-(
All ideas and thoughts appreciated. Thanks...
