Thread: Anyone Have a Wire Map for the Ignition Switch w/Steering Lock?
    Oct 2009
    Indiana
    We are trying to get the wiring harness completed and completely checked on my '68 911, and although I know it is last-minute, I am hope that someone can help....
    I need a map showing which wires connect to which posts on the back of the ignition switch. We marked the wires when we removed the switch, and we have a wiring diagram, but there appear to be extra wires.
    Does anyone have a photo of the back of the ignition switch with correct wires in position?
    Thank you, in advance.
    Even if I could get a picture of the back of the switch it wouldn't do you any good since you couldn't see the terminal numbers on the back of the switch, but the wire s attach thusly; Term. 30 is hot, it gets a red 6mm wire from the light switch, and a red 4mm wire that comes from the hi-lo steering column switch. Term. 50 is a 6mm wire to the starter solenoid. 15 is ignition on and goes to the hot side of fuse one. Term. 75 should be a red/white wire which is to power the radio. Term. 57 should be a white or gray wire also going to the hi-lo switch. What do you have left? There may be stuff people have added. It's amazing how some of this wiring gets butchered.
    Oct 2009
    Indiana
    Ed, you are one of the scholars that give so much value to this registry. I will try to follow those instructions. Thank you.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    The real question is... Ed, did you pull that off the top of your head?
    Mark..
    Most of it,,,
