Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: WTB: hood Crest pins
    Senior Member seareef's Avatar
    May 2016
    No rain so cal
    So I came across an og orange bar hood badge missing or should I say cut pins ..I am looking for 2 or more pins on the back of the hood Crest so I can reattach them.
    Feb 2016
    San Clemente, CA
    I only know of finding a broken one and harvesting the pins off of it. Carful soldering these back on.
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    Hi Ron
    I've got remanufactured pins made by an engineer really close to the original spec and exact same size but I'm in the UK. Not sure how cost effective or how quick they would be to get to you. They weren't cheap to get turned up so if you don't find any local or from another badge (post 73) I will help.
    Resoldering is tricky but it's the only way to get a lasting secure job. I've tried every epoxy known to man and they all work for a while but eventually give way. I re-solder all mine now.
    By the way, in your picture the shaft of the pin has broken off (or been cut off to fix the badge to a flat surface) leaving the base of the pins still soldered to the badge. An very tricky repair.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    May 2016
    No rain so cal
    Quote Originally Posted by 210bhp View Post
    Hi Ron
    By the way, in your picture the shaft of the pin has broken off leaving the base of the pins still soldered to the badge. An very tricky repair.
    Mike
    Hi Mike I would be interested .. I don't care how long it would take I was thinking about making my own and I thought about what was close and my spitznagel gun uses the same type of stud that would be pretty easy to modify .I can carefully dissect those pins off and make it look like they were never there and then take it to a jeweler and have him solder it on that's my plan
    Feb 2004
    Scotland
    You could have a go Ron. Making the pin might be your easiest task (the diameter of the pin is the important measurement). The trick is soldering to a secure finish without the heat destroying the enamel on the other side.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    May 2016
    No rain so cal
    Mike
    Hi Mike p.m. sent yes I could make it and the diameter is identical but yours are plated hahaha
    May 2016
    No rain so cal
    Quote Originally Posted by trdking View Post
    That might be a sin ...lol.haha��
    Jul 2011
    Chicago Area
    Pretty sure some of the older 356 hubcap centers have the same mounting pins, might be able to find a cheap one or someone who will give you one.
    Mike Fitton # 2071
    2018 911S Carrera White
    May 2016
    No rain so cal
    Quote Originally Posted by mfitton View Post
    Smart idea Mike
    Bone stock roofing nails are a dead ringer. Just trim to length.........
    1969 911 E #824
