Results 1 to 7 of 7
Thread: Horn help
    Member gkahrs's Avatar
    Apr 2014
    KANSAS
    Horn help
    All,
    does anyone know of someone who restores the banjo horns. I'm finishing complete rebuild of my early 73 targa and need the horns i have restored so they look nice and work again.
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    What is the build date of your car?
    Shouln't 73 have trumpet horns and not banjo horns?
    Can you post a picture of your horns?
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    Trumpets after January 73, more or less.
    How bad are your horns? Buy a new set of black trumpet horns remove the trumpets, and switch your plastic banjo's to the new electric portion. You can use plastic cleaner and polish to clean up the banjos.
    Oct 2010
    Florida
    This thread has more about horns. Here's even more. Search is your friend.
    Name:  911 Trumpet Horn.jpg
    Richar Newton
    Are Your Brakes Getting Hot Enough?
    Apr 2014
    KANSAS
    So the electric portion of the new replacement trumpet horns will fit the Banjo plastic?
    My early '73 had Banjos. I think they were used until the first quarter sometime of 1973. My car was built 9/72.
    I do not have any pics.
    here is a picture of the electrical portion of the banjo horns, they look identical to the trumpet electrical, as seen above.
    Certainly worth a try, I can't see a difference. Except for the type of connection.
    http://www.early911sregistry.org/for...ht=banjo+horns
    Apr 2014
    KANSAS
    I think you're right. I'll let everyone know if it works.
