Thread: '73 911 Radio
    Member gkahrs's Avatar
    Apr 2014
    KANSAS
    '73 911 Radio
    Looking for an appropriate us radio for a 9/72 production date '73 911. I would need all the accessory pieces as well.
    Nos is best, i will consider anything.
    Back up plan is a radio delete plate.
    Jul 2011
    Chicago Area
    Do you have your COA with a radio listed?
    Mike Fitton # 2071
    2018 911S Carrera White
    Jul 2011
    Chicago Area
    If the COA calls for a Frankfurt, this is what you need. I have the correct faceplate for your smooth vinyl dash if you are interested. '71 & '72 Blue dot Frankfurt's are the same: http://www.radiomuseum.org/r/blaupun...262776326.html
    Here is mine: http://www.early911sregistry.org/for...kt-AM-FM-914-6
    Mike Fitton # 2071
    PM sent...I have a Becker Europa that was factory installed in my highly optioned 72 911 including an amplifier and plug in for external devices.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Apr 2014
    KANSAS
    COA says antenna only. No mention of a radio. Radio delete plate it is then.
