Thread: 1968 Ignition Switch
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    My US 68 has an ignition switch that resembles the one pictured below, on the right. The terminal descriptors are quite different from those I generally can find anywhere . They usually look like those in the second image (bottom left). The dotted lines in that diagram are also unclear as to where they end (the grey one for example).
    Can some one give me an indication of which wire goes to which terminal on my switch?
    Name:  Ignition Mayhem.jpg
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Apr 2012
    Simi Valley Ca
    Jan 2013
    After 2 days of searching I found an old file that presented the "Inland" and "Export" different versions of the terminal coding on the early cars, by Roger Chaney. Pure gold! All sorted now. It seems that someone was in thew past playing around with the terminal connections on my 68 and also there were some few remains of an old immobiliser system. Now back to standard ignition electrics for US delivered car.
    Merv
    Member # 2633
    Cars:
    Merv, what a handsome, knowledgeable, true enthusiast must have annotated that wiring diagram!
    Jan 2013
    Yes. The original was called, IIRC, the "Up-Fixen #4", or similar. Thanks for your help with this.
    Name:  911E ignition switch 001.jpg
    Merv
    Member # 2633
    Cars:
