Results 1 to 10 of 10
Thread: Fire Extinguisher Mount?
    Aug 2013
    SoCal
    I have a rennline mount that moves with the seat in my 993.
    What are people liking to mount their extinguishers in the early cars? I've gone to effort and trouble to restore the car - -n ounce of prevention can't hurt...and you can't use an extinguisher if it's not accessible.
    I mount mine to the rear shift cover plate.
    Fire Extinguisher mount
    Made this mount from .090 aluminum and it was pop Riveted to the passengers seat in the 1965.
    Moved with the seat. Out of the way. Did not hinder passengers foot space or entry/egress.
    Once it is installed the bracket mount is not seen. This is how it fits in a newer 911.
    (Was made a few years prior to the BK mounts.)
    Bob
    Early S Reg #370
    Oct 2010
    Florida
    The real danger here is that the extinguisher comes loose in an accident. A friend of mine was killed when the extinguisher broke loose and hit him in the head.
    You don't want your extinguisher to become a deadly missile in an accident.
    This is really scary.
    Richard Newton
    Should I Restore This Car?
    I'm a cheapskate, I mounted mine on a piece of aluminum angle and noted it to the height adjustment bolts at the front of my seat. Moves with the seat too.
    I mounted it to the drivers seat, as I don't want my wife complaining of snagging something.
    Aug 2013
    SoCal
    thanks for the responses. I'm comprehensively restoring my car back to factory specs, and wanted to protect my investment. My hope is to find something close to what might have been available in period, but also make the extinguisher available should the worst start to happen.
    Oct 2010
    Florida
    If you're going to put a fire extinguisher in your car you should also go to a local fire fighting school and learn how to use the extinguisher. That's sort of important.
    Richard Newton
    Preservation, Conservation and Restoration
    Quote Originally Posted by Richardnew View Post
    Richard Newton
    We have this training at work. Also have the right extinguisher for the type of fire...
    Peter Kane
    '72 911S Targa
    Oct 2010
    Florida
    72targa - Very good point.
    Porsche engines present a unique situation. If you have a magnesium case that Home Depot extinguisher is useless.
    Richard Newton
