Thread: FS: 2.7 CIS Shrouds (Green) 2 Available $150 each
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    Two original green 2.7 shrouds. My apologies for the mix up.
    Shroud A has one whole around fan assembly with a crack; all other holes are fine. Shroud B has one whole around the fan assembly and one at the engine breather area.
    $150 each not including shipping. Located in Seattle, WA.
    Thanks!
    IMG_5234.jpgIMG_5233.jpgIMG_5232.jpgIMG_5231.jpgIMG_5230.jpgIMG_5229.jpgIMG_5228.jpgIMG_5227.jpg
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Those are both 2.7 CIS shrouds but couple easily be modified for MFI. The 2.4E Green MFI shouds would have the semi-circles cut out for the injectors.
    Oct 2010
    Seattle, WA
    My bad. I will revise the ad. Thank you.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
