Thread: Best source for brake parts 1965 911?
    Dec 2016
    Long Beach, CA
    Stoddard, PMB?
    Nov 2002
    San Dimas, CA
    PMB really knows brakes, but what do you need? Something esoteric like those funny things that live inside the pistons or everyday stuff like brake pads?
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Dec 2016
    Long Beach, CA
    I was planning on rebuilding the calipers, chaning pads i have a caliper dragging and its been over 25 years so its time
    Nov 2002
    San Dimas, CA
    I did that a while ago. You can probably get genuine Ate seals from any of the usual suppliers--there are many choices in pads...
    I recommend you talk to PMB. Right now, their website shows a rebuild kit for only "S" calipers but at the very least you might want to ask them about "heat cycling" after you install new seals.
    There's a tendency for new seals to grab the pistons and pull them back, giving you a low brake pedal. By "low" I mean the pedal will go all the way to the floor and you may have to pump a few times to get any brake action at all. The cure seems to be taking your brakeless car out for a few panic stops. It doesn't sound like a good idea but if you can bring the car home reeking of burning brakes the seal sticking can be cured.
    Jim Alton
    Torrance, CA
    Dec 2016
    Long Beach, CA
    Tx jim. Won't know what I need til it's torn down.
    Feb 2016
    San Clemente, CA
    http://www.early911sregistry.org/for...MB-Performance
    Here is the contact for PMB and a pic of my fresh restore of OG 65 calipers
