Results 1 to 8 of 8
Thread: PY65 MY66 302562 Horn Grill
    Dec 2016
    Long Beach, CA
    After reading for an hour or so i cant tell if i should track down 4 screw or 2 screw horn grills for this car as i will need them after putting correct fenders on the car. This car is also a european delivered car if that makes any difference. I know i missed a post which answers this somewhere?
    Merry Christmas eve
    Seattle WA
    Hi Chuck,
    I think this is the thread I mentioned to you. The first car listed was owned by a friend, 302947 and it was a 4 screw grill car. Lots of good info in that thread.
    http://forums.pelicanparts.com/porsc...-66-911-a.html
    I also mentioned to you a "truth table" thread, and I don't think that's the one, perhaps others can mention it.
    Merry Christmas!
    Eric
    Oct 2008
    Burford, ON, Canada
    Yes, it would seem that 4 screw grilles and matching fenders will be required. The changeover seems to be between 3150 and 3400.
    Nov 2002
    San Dimas, CA
    If you're not fanatic about originality, your body shop can weld tabs for the four screw grill's four screws into the opening. Nobody will see the tabs with the grill installed.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Dec 2016
    Long Beach, CA
    Quote Originally Posted by Soterik View Post
    Hi Chuck,
    Merry Christmas!
    Eric
    Thanks again. Merry Christmas!
    And if your body shop is good they will make the tabs in such a way that you cant tell that they are not original - along with most likely making the fender lip even and modifyiing the headlight bucket
    Membership #3255
    301022
    revivem.co.nz
    I have a matched pair of the 4 screw horn grill for sale if you are looking for them.
    Dec 2016
    Long Beach, CA
    Yes I'm interested. . Tx Chuck
