Thread: Simple question: 901 shifter shaft diameter?
    Sep 2012
    Colorado
    Merry Xmas folks. I have a simple question that I'm not at home to answer for myself right now. What is the diameter of the shifter shaft end on a 901 transmission? Somebody gave me an early 356 shifter knob (10 mm) as a gift and I don't think it will fit.
    Rich
    I think its 16 mm.
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    Mar 2006
    Louisville KY
    The non threaded shifter is 15mm
    Tony Proasi
    52 split window coupe
    Sep 2012
    Colorado
    Thanks! Merry Xmas.
    Rich
    Feb 2016
    San Clemente, CA
    Except a 901 shaft is threaded?
    Shift levers for all 356, 911 and 912 models from 1960 through mid-1967 had 15mm threaded ends.
    Your 10mm knob is for 356 models before 1960.
    Jon B.
    Vista, CA
