Thread: 70-S - blower motor testing...
    I would like to test this blower motor for its 3 speed operation...re the attached photo can anyone tell me which of the posts are the ground, first, second and third fan speed? Thank you.
    Apr 2013
    Clayton, NC
    Any feedback, as I would be interested in know this as well?
    I just use a 12 v battery, jumper leads, and bench test it. Just determine which post is ground.
    Oct 2010
    Florida
    I'm doing the same thing with my '73. I used a VOM meter at the plug. I have power at the plug. The motor doesn't activate though.
    My next step is to take the motor out - and apart. I did this about 10 years ago and the blower magically started working. I suspect that my brushes are shot this time. We'll see.
    I might get to all of this over the weekend. We'll see.
    Richard Newton
    Garage Lighting
    Using my photo as a reference, the incoming RED power wire connects to the top left terminal and the BROWN ground wire connects to the lower right terminal. The other two studs - at least looking in through the fresh air valve hole - have no wires connected.
