Thread: RSR oil cooler?
    RSR oil cooler?
    Hello,
    I recently purchased a '74 targa that was equipped with RSR fuchs.
    Some people say the front oil cooler is also RSR. Is this true?
    Thanks in advance!
    Kind Regards,
    Johan
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    What's the difference between heroin addiction & P-Car projects? Heroin use has it's limits.
    Factory coolers were Behr from what I know. Yours is an aftermarket similar to this...
    http://www.ebay.ie/itm/PORSCHE-901-9...JhXctKi8wRWEew
    Peter Kane
    '72 911S Targa
    All the factory oil coolers I've seen have both oil fittings on the same side, both in one tank.
    Aug 2007
    Phila Pa. area
    73 RSR oil cooler
    That is an aftermarket cooler. The 73 RSR factory cooler had the in and out on the passenger side and the dimensions were approx 21 inches from left to right, 4 inches high, 4 inches deep.
    Mike Curnow
    Mike
