Thread: Question on interior insulation material
    I've read the many threads on which materials are better. I also see that Stoddard is now offering a set up. This got me to thinking, does anyone have a computer scan of the various pieces of sound deadening materials? I would assume that Stoddard's are cut via a cad type machine. If their were such a pattern available, you could simply print to size on paper the various pieces, and then use those paper pieces as a template to cut your own out of the material of your choice. Has anyone ever seen a measured set of those, or have a computer scan of them? Thanks Steve
    1969 911 E #824
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    Hello
    So what is considered the best insulation material? I pulled the insulation material out of a 70 Coupe, even the bottom side of the roof had insulation.
    Rodger@orbitracing.com
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Once you determine what kind of insulation you want, it isn't all that difficult to cut patterns by hand using construction paper. I used dynamat insulation but didn't want to get the goo on the painted chassis (it is impossible to remove) . So, we applied the dynamat to thin jute backing and then cut the resulting composite using the patterns. Makes for a lot less messy install.
    Oct 2010
    Florida
    I cut mine by hand. I used Wurth because that was the closest to OEM. You want to be careful that you don't use a sound deadner that hold water. A lot of the jute types will. That's just asking for rust issues.
    Name:  911 Floor  Resto 3.jpg
    Richard Newton
    Historic Racing Images
