Guys
Need the check valve on 73.5 CIS fuel pump.
This mounts to the fuel pump via a hollow bolt .
thanks for assistance
Frank
Guys
Frank
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
Frank,
Dumb question but have you checked Porsche?
Frank B
Yes , they are available but vary from $85 to $72 for Porsche version plus the banjo bolt another $10
Just seemed expensive for something that common to the CIS fuel pump.
I did order on Saturday after no quick response, probably better as read these can cause issues if not doing their job of checking! ........much like our border patrol.
Frank T
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
Actually it's a pretty special little part; check valve is in the banjo itself. 73.5-74 only I believe.
The bolts last forever.
Good luck.
Yes believe your correct on Year but think I have you on the check valve # 911 608 912 00
Description states this houses check valve the banjo bolt is hollow type with hole for flow to the valve in the connector.
Thanks for note
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
Original barbed banjo fitting is 911 608 901 00 and has a built in check valve.
Does yours look like this?
Here is my rebuilt fuel pump and my original check valve and bolt...
can't tell from this photo...... but sure your right based on your photo but then don't understand why they sell separate and the Check valve is $85 and the bolt is $10....
Could there have been 2 styles ?
Thanks for note/photo......For now you win
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
Frank, it's not about who wins or loses; it's about me being right and eventually getting a lot of money for my NOS 73.5 check valve.
I'll wager a used reproduction hood badge that what you're going to get is a barrel valve that screws into the pump and a cap nut. (Like the one on the right in the pic below.)
That will leave you with sourcing your own banjo fitting.
Frank
Agreed ....all for big $ for NOS parts.
Will post photos of new Porsche version when arrive.
If I knew you had the NOS would have probably paid double the cost of new.
Again thanks for you info
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
So I have now received the new check valve part and hollow banjo bolt.
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
