Thread: Front & engine compartment correct black coating on an early 911S SWB
    Member mbracing61's Avatar
    Jun 2008
    Milan, Italy
    Hi all,
    In the process of finishing my early 911S (Nov. 1966) full bare shell restoration this is to ask what kind of black paint or coating you suggest as the most similar to the original for the interior of the front and engine compartments, and if there is somewhere a photo reference to see where it should be exactly applied.
    Kind regards and an Happy New 2017 to all members!
    mbracing61
    Nov 2002
    San Dimas, CA
    I've used Würth High-Build Underseal in my car's engine bay, although my car's a bit older than yours.
    It's hard for me to tell the fresh Würth High-Build Underseal goo from the original goo.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Jun 2008
    Milan, Italy
    Thanks NeunElf. Anybody else with another suggestion for a factory-correct black finish?
    Apr 2011
    N.Calif., south of SF
    Wonder if a zinc based etching primer would be a good base prior to a black coat?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2013
    Europe
    We always use 2k epoxy (black in case of black finish) or etch/wash primer (black...) to start on bare metal. Then a primer, underseal, (coat and clear coat). For underseal areas mostly wet-in-wet can be applied.
