Results 1 to 7 of 7
Thread: FS: 2.0, 2.2 Distributor
    2.0, 2.2 distributor rebuilt within last 1500 miles by Partsklassik, P/N 231 159 006 with 27 mm shaft. Has been on a 2.7L early alum engine, being replaced by a twin plug distributor.
    $450 plus shipping. gbmotorsport@gmail.com
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Gib, would the curve work well for a 70S engine?
    Rusty
    ps: you're an inspiration to most of us wanabees
    Dec 2008
    Black Mountain, NC
    006 was the E distributor, 007 S, curve may have been adjusted at rebuild, or could be now, beats the hell out of the Merelli either way if you still have one.
    Yes, Rusty, it will work with a 70S with the addition of a new S rotor.
    The 2.2E and 2.2S have the same advance curve built into the distributor. The only difference between the E an S is the rev limiting rotor. This distributor has a non rev limit rotor because I was using Partsklassik's CDI with rev limiting built into the box.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Still available....
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Still available.....
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Feb 2012
    Netherlands, Leiden
    Will this work on a 901/10 1969 2.0S engine?
