Thread: 3" Brembo alloy lightweight calipers, completely restored
    Dec 2014
    Motor City
    Folks,
    Happy New Year! Offering a final set of calipers here.
    See photos. Cores were from an 20k mile California and are the nicest I have dealt with. I think these could be pegged as "show quality."
    These calipers were stripped, x-rayed, glass blasted, bright dipped, and then anodized in black.
    Rebuild:
    Re-plated original Brembo bolts
    Pistons polished original Brembo units, installed with proper "clocking" template
    All new rubber (ATE and Akron), dust hats are OE Brembo
    Re-plated hardware and spring clips
    Caliper spacer O-rings are new ATE square-cut viton units
    Bleeders are re-plated Brembo - high offset units which allow easier bleeding.
    Calipers are multi-stage torqued and Vaseline-rubbed, ready for installation.
    Extra set of plated bleeders and OE Brembo dust hats inculded
    Sold as pictured. Not shown: I have a set of hard line adapters and brake pads I will include if wanted that allow these to be a "bolt on" upgrade.
    Offered for $775 shipped in the USA, but I will ship worldwide. You will not be disappointed with these.
    EDIT, SOLD THANK YOU ALL
    20170107_130104.jpg20170107_130148.jpg20170107_130156.jpg20170107_130107.jpg20170107_130109.jpg20170107_130212.jpg20170107_130217.jpg
    Rob
    Dec 2014
    Motor City
    Slight price drop, will be including pads, hard line adapters, spare bleeders, and hardware.
    Rob
    I bought a set of these from Rob back in November to put on some 3"spaced T struts I am putting on my 914 and I can't say enough about the quality of the rebuild and finish.
    -Andrew
