Thread: Becker radio install in swb
    Jul 2008
    near Ottawa, ON,canada
    I was lucky enough that the previous owner kept the original radio even if it was not working
    Cost more to fix then buy a new one . Grin..
    The dash is unmodified
    Its a becker grand prix with the amp at the back
    But i assume its not just held with the post
    But there does not seem to be any holes for a bracket
    So does any one has a picture of it and where it goes
    Thanks in advance
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Jul 2011
    Chicago Area
    Mike Fitton # 2071
    2018 911S Carrera White
    Nov 2003
    Sydney
    F 14,
    when you go to install the amp,you might consider putting it under the passenger's toeboard.
    I did this with my RHD '71 S and it worked well.
    The GP takes a couple of seconds to warm up but its a great radio even after you turn the motor on !
    HTH
    Dennis
    S Registry member 536
    Jul 2008
    Ok so after looking at it some more
    Found that the radio mounts alone with a nut at the back and a small bracket
    The hole from the original install was there
    So you install the radio to the body then you add the amplifier to the mounted radio
    Et voila
    2 weeks and the new knobs will be here and i should be done with the radio wiring
