Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Front Lisc. Plate Bracket
    Oct 2010
    Florida
    Name:  911 frt. Lisc. Plate Bracket.JPG
    Was this list. plate bracket a factory item? Or, did someone fabricate it?
    Richard Newton
    Factory bracket Richard,,,
    Jul 2006
    Switzerland
    Legally, any front plate needed to be vertical mounted, for better reading by Police etc..hence the OEM bracket.
    Visually , I never was a fan of it and actually prefer w/o it. Nowadays on a vintage car, its usually accepted.
    Registry member No.773
    Oct 2010
    Florida
    We don't use a front plate here is FL but I had never seen this bracket before. Now I have to check and see if I have holes in my front where this may have been attached at one time.
    Richard Newton
    Is Your 911 Staying Warm?
    Feb 2016
    San Clemente, CA
    Quote Originally Posted by 911T1971 View Post
    Here in California, it is the law. You must run a front plate. I do see a lot of leeway omitting the plate on classic cars here Except if you run the toll roads. They like a picture of the front and back of your car. Cops on the toll roads will pull you over and cite you for no front plate for this reason
    Aug 2013
    SoCal
    its pretty ungainly...
    Something at which to aim LIDAR.
    Early S Registry #235
    rgruppe #111
    Nov 2002
    San Dimas, CA
    That's a factory front bracket for the European front number plate which is wider and narrower than an American license plate. For better or worse, I decided to adapt that to mounting my front license plate. Now that I have expensive Year of Manufacture license plates I'm damn well going to show them.
    I believe the factory solution for American front license plates was two little moldings or castings which were to be screwed right at the rubber deco--maybe even through the rubber trim. I can't find a drawing of those right now.
    License plate mounting varies quite a bit. I've seen long-hood 911s with a front plate screwed directly to the front bumper. Previous owners screwed the rear license on my car directly to the rear "center part" but many cars have a VW license plate bracket there.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Oct 2010
    Florida
    That's why I started this discussion. Most Americans seem to have screwed the plates directly to the bumper.
    The fact it's a Euro part also explains why we haven't seen this item very often.
    btw - What is a Year of Manufacture plate?
    Richard Newton
    FIA Historic Rules
