Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Radio plate cutout. Is this correct??
    Senior Member seareef's Avatar
    May 2016
    No rain so cal
    Hey guys I bought this from Sierra Madre company and obviously looking at the pictures it's off center is it supposed to be this way or did they Name:  20170113_180846.jpg
Size:  66.3 KBmagically laser cut it off center?
    May 2016
    No rain so cal
    Anyone?,,..........
    That's the way they are supposed to be, as original. Look at any factory photo of a dash. Install so that the radio sits lower, thicker side of plate up.Name:  L1030624_2.JPG
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    May 2016
    No rain so cal
    Quote Originally Posted by smedley View Post
    Yes I understand that I am talking about left to right side to side
    Jul 2011
    Chicago Area
    I believe he is referring to the cutout not being centered left to right. It will work as is, I believe some of the earlier SWB cars had it off center because of fitment on the dash with the left side being longer. The thicker side does go on top above the cutout as mentioned above. This plate was made to work with both the SWB & LWB.
    Mike Fitton # 2071
    2018 911S Carrera White
    May 2016
    No rain so cal
    Quote Originally Posted by mfitton View Post
    Hi
    Mike
    I have a 69 coupe should I just use this one OR
    Should I hand make one that's center from left to right ?
    Ron
    May 2016
    No rain so cal
    Any opinions would be great??
    The photo I posted above is my original '69 T.....I really don't know if it has any variance side to side, and you can't tell from my photo....I'll go out to my garage and take a look.....film at 11. My '67S has it's original dash, but it has a block off plate covering the holes. So I can't check it.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Have you tried lining up the cut-out plate to your dash yet?
    May 2016
    No rain so cal
    No why do you ask ? It should slide right in
    ,I would hope..
