Results 1 to 9 of 9
Thread: 70 911T with Carbs-FUEL PUMP???
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    What is the best option to end up with the most reliable fuel pump for my 70 911 T with carbs? If there is a new one I can buy that is as reliable as the original I would do that. I have heard that rebuilding the original one might be a more realiable solution. If so, who rebuilds the fuel pumps?
    Thanks you for your help.
    Rodger@orbitracing.com
    Roger, Fuel Injection Corp. in Ca.
    Banned
    Nov 2004
    Scottsdale, AZ
    You should install the proper fuel tank while you're waiting the 2-3 weeks.
    Also , make sure you replace those old fuel lines .
    And fuel filter and fuel accumulator.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Jul 2014
    Long Island NY
    I had my original pump rebuilt on my 71 T, seems to work just fine. You can find NOS out there, but very pricey
    Oct 2010
    Florida
    Fuel Injection Corp is the only way to fly.
    Name:  911 Fuel Pump 6.jpg
    Do the tank, the filter and the lines at the same time. "As long as ........."
    Richard Newton
    FIA Historic Rules
    Aug 2009
    SF Bay Area
    Frank
    What's wrong with a later tank? After all, the owner will be able to travel another 100 or so miles between fillups.
    Ciao
    Jim
    Banned
    Nov 2004
    Scottsdale, AZ
    Jim,
    I know Rodger and it would shock me if he would want anything other than original.
    BTW: Those beers you sent me have already turned to wastewater. Awaiting more.
    When does Pliny the Younger make an appearance?
    Aug 2009
    SF Bay Area
    Jim,
    http://tenemu.com/uncategorized/russ...-feb-3/01/2017
    Ciao
    Jim
