Thread: installing window felt
    Jun 2011
    Bellingham, WA
    I will be replacing all of the felts. How do I install the horizontal felts into the holes? My fingers aren't strong enough to push in and I don't see a way to use a pry bar (plastic)
    Jul 2008
    near Ottawa, ON,canada
    The way i did it is on a hot water bath with lots of dish soap and patience
    Once you have about an inch in you have to pich at the edge and push it in
    It wil.go about half and inch each pass
    It will take you a good 20 minutes each
    Good luck
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Quote Originally Posted by 72t4tom View Post
    Assuming you mean the felt strip along the top edge of the outer door skin with the 4 metal push tabs, if you have trouble pushing the pins in try using some kind of plastic or wooden wedge that you force down between the two panels.
    Oct 2010
    Southern Ca.
    If you are installing new strips , I think it helps to squeeze the tabs ever so slightly with pliers before installation .
    Sep 2013
    Kalamazoo, MI
    Very strong fingers and lots of grunts.
    Jun 2011
    Bellingham, WA
    So I should install the felts before I re-install the frame & glass. A-HA!
    Thanks everyone
