Thread: Engine start up question on oil pressure
    Jul 2008
    near Ottawa, ON,canada
    Ok i am getting close to the critical moment
    I have butterfly in my stomach but i.have an oil pressure question
    Car is 68 911s with stock rebuild
    I have filled the engine with 9 liters of oil as well as break in additive
    Its about 40 F in the garage
    Oil is 10w40 conventional
    When i crank with no plugs in the head
    The druck gauge reads close to 2 (scaled from 0 to 10)
    Whats the unit and is 2 a sign to go to next step
    Is it too high
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    That's about 30 psi, you're good to go to start it up. (and that's too damn cold to work in the garage )
    Jul 2008
    It might too cold but its still better than the 15F outside
    Nov 2009
    Cecil pa
    With your rebuild about to crank over, twin heaters overnight and part of the day would bring temps to about 55 F.
    Break-in as important as it is, why not maximize oiling on all surfaces ?
    Nov 2003
    Santa Monica CA
    I would put a warm up blanket on the engine overnight before starting even at 40 degrees. but that is just me. chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Jul 2008
    Well i used a large halogen light and set it under the engine
    Chased ignition issues but in the end it did come alive
    The longest 20 minutes of my life
    Idles a bit high now and pops but that things revs so fast with a minuscule throttle input
    Small oil leak on chain covers quickly fixed
    Dumped the oil right
    Now tuning
    I assume the popping is due to lean condition
    My plan is to get a colortune to start and go from there
