Results 1 to 10 of 11
Thread: Bosch distributor repair
    I have searched this forum for this topic and came up empty. Any one have an info source for the do it
    Your self type. What little I have found refer to spring, magnets, grease etc. just need a littl direction.
    The cost of having redone commercially would imply there's allot to it but want to do it myself if possible.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Its not the disassemble / reassemble that is hard. Its the knowledge about what to look for, how to set up, the equipment to spin and adjust that makes it hard or impossible for the do for the "do it yourself-er" to do.
    You might research here a little
    http://advanceddistributors.com/wordpress1/
    Jeff is a very knowledgeable guy, he may be able to help you out.
    Mark..
    Mar 2013
    Surrey, UK
    I'm sure Barry Hershon could sort it for you: barryhershon@att.net www.flat6recurve.com
    For cleaning and lubrication see here: http://forums.pelicanparts.com/porsc...utor-lube.html
    If it needs to be rebuilt, you need a professional with a distributor machine and access to Bosch parts.
    Barry can do it, I have used him, but he is expensive.
    I have used Ed Fall at Vintage Werks with great success: http://www.vintagewerks.com/
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Barry did mine, he said that my distributor was worn out 100k ago ;~)
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Thanks everyone for the imput, pretty much what I thought.
    Grumpy, clearly a car will run a long time with out being perfect
    Thanks again
    I think Partsklassik offers rebuilds too.
    Junior Member
    Jan 2010
    Ann Arbor
    Barry Hershon in Detroit.
    Carbs-Fuel-Ignition (CFI) does early 911 distributors (also 356/912):
    http://www.sparkingplugs.com/4.html
    http://www.sparkingplugs.com/9.html
    +1 Ed Fall and I'd give Kurt a shot as well. Just don't have anything for him right now..... I think.
    Early S Registry #235
    rgruppe #111
