Thread: Front sway bar bushings
    i've taken out two before, but now can't remember how to remove the front sway bar bushings to get the bar out. I have the fuel tank removed, do I punch it out from the inside? Thanks for any help.
    John Schiavone
    Connecticut
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by John912 View Post
    this can be a PITA when they dont come off the cover..use a heat gun or if this does not work burn one with a torch to get the bar out of the car
    Dec 2008
    Black Mountain, NC
    John, you may try a spray lube on the thru the body bushings and a rubber or dead blow mallet "tapping" the end of the bar from one side toward the other, go from side to side may get you some play to move the bar / bushings, yes the bushing comes out to the out side. Hope you are well.
