Thread: Window winder handle repair available?
    Nov 2006
    S. F. Bay Area
    Anyone know of a place offering to repair the knob on an earl('67) window crank?
    Knobs are loose, fear breaking off. Thanks
    Brian
    S Reg #1032
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    My SWB has gone and I don't have any handles to check! but assume they are similarly attached like the LWB ones. Try carefully peening the rivets over to tightened the knob. I repaired a friends LWB winder by drilling out the rivet, cutting it flush and tapping a thread into the knob, then screwed a flat headed screw in from the back. Worked well and unnoticeable unless dismantled.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    You can buy excellent repros here:
    http://www.autoforeignservices.com/index.html
    Aug 2009
    SF Bay Area
    Eric's excellent handles are for 66 and earlier. A 67 handle is different.
    Jim
    Nit picking Curmudgeon
