Thread: FS: Mag case 901/13 transaxle
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    **** S O L D *****
    Rare 911 901/13, 1968/9 only model, magnesium case, which was 911E and S models. 5 speed, original gears would be AFMSZ
    901/13, magnesium case
    ser #7197017
    911 1968-69
    5-speed synchronized transaxle
    Rod shift
    Single-plate clutch
    Gear ratios:
    1st gear: 3.091 (A)
    2nd gear: 1.889 (F)
    3rd gear: 1.318 (M)
    4th gear: 1.040 (S)
    5th gear: 0.793 (Z)
    Ring and pinion: 4.43 (7:31)
    It's not a core, it's a good working transmission that had no problems when I pulled it from the car. It's dry and doesn't leak. Note it still has correct early axle flanges (4 bolts, 2 pins).
    Ships from Calgary, Alberta, Canada T2T 5S8 (if you want to estimate shipping).
    $1800 USD (+ PP fees)
    Cheers,
    **** S O L D ****
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Quote Originally Posted by lkadams View Post
    Rare 911 901/13, 1968/9 only model, magnesium case (this is the only mag case 901), which was 911E and S models...
    911 1968-69...
    Manufactured by Porsche (ZF)...
    Keith, this is a 69 model only.
    It was the only standard mag case 901 5-speed, but there was also a mag case 901 4-speed standard on T and E (US) models, 901/12.
    The only ZF-made part of a 901 transmission was the optional Limited-Slip Differential.
    Jon B.
    Vista, CA
    912->911 conversion
    Nov 2004
    Thanks Jon!
    Keith Adams
