1970 911 S Cylinder Heads, no valves or springs, Valve guides removed, Combustion chambers modified to clear 92mm RSR Hi Compression pistons, 36mm Intake ports/ 35mm Exhaust ports, All date stamped 8/69
$800 for. all 6 Cylinder Heads
Contact rodger@orbitracing.com
