Thread: SEEKING WISDOM: Photos of the Location of Electrical Relays for '68?
    Oct 2009
    Indiana
    Friends,
    We are sorting out the wiring harness of my '68 SWT, and I am trying to find the correct locations of the electrical relay boxes. Right now, we have one in the far front corner (driver side) next to the washer reservoir.
    We also have three relays in place on the cowl (one behind the speedo, and two toward the passenger side under the cowl. (The turn signal flasher is also on the driver side, under the cowl).
    If I am reading the wiring diagram correctly, there is at least one more relay box, but I can't figure our where it is supposed to be located.
    All wisdom is always appreciated. Thank you.
    Just in case a pic helps?
    Alan
    Behold, the definitive SWB relay thread: http://www.early911sregistry.org/for...elays+analyzed
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    I shot hundreds of photos before I started taking the car apart. This is a 68 911. Its a Karmann car which I have found does not always follow the coloring of the wiring as shown in the schematic. Name:  RelayPanel_2.jpg
    Tony
    68 Sporto Project
    2016 Boxster
