Thread: Floor pan Assembly
    Aug 2011
    Virginia Beach Va
    Floor pan Assembly
    I been looking to buy a front suspension pan. After checking my pan I need more than just the front pan. It appears that I am going to need the rear bulkhead wall which attaches to the tunnel and front floor pan. has anybody seen this part? 911-501-955-00-GRV in person?
    have you worked with it? ? does it have all the suspension points welded in? Will it fit a 1966 SWB? Any information would be appreciated.
    Doug Lehman
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Doug
    Having a hard time understanding what you want based on part number. Is that Porsche's number? Look on Restoration Design. Probably cheaper and not a Dansk one size fits all. Their's is P218A or B. However they relate it to 911-501-954-00. 955 is probably a revision. Guys on here can tell you for sure.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    on SWB two of those mounting points are about 3mm higher than on LWB always forget which ones--- the rear or the front ones.
    need to have a look tomorrow at my celette
    Aug 2011
    Virginia Beach Va
    Did you ever find out what is the difference
    Doug Lehman
    Member #2825
    1966 912
