Thread: The Definitive Inner Fender Thread
    I've heard rumblings that more discussion is desired on the subject topic...
    Reference threads here...
    http://www.early911sregistry.org/for...-wheel-housing
    http://www.early911sregistry.org/for...-Panel-1965-66
    Commence discussion!
    Peter Kane
    '72 911S Targa
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    to be updated asap
    Seattle WA
    Ok Moito,
    Can you tell me why the bottom one is both 68 and 69? Or is what you're saying that it can also be used for 68? even if it has the larger hole for the wiring at the back end.
    Eric
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Soterik View Post
    Ok Moito,
    Eric
    my 68 911L (11810708) already had a bigger hole than 67 -- it did not have the big 69 connector though.
    same for a friends 68 912 (12804236)
    need to have a look at some detail pics i have of this area and compare--maybe the 68 hole was not as big as 69 and did not have the 69 recess.
    in this case the bottom pic is 69 912 only
