Results 1 to 7 of 7
Thread: 1973 Targa - Felt in window guide - rear side of door
    Junior Member Benrenn's Avatar
    Jan 2017
    Houston, TX
    Question 1973 Targa - Felt in window guide - rear side of door
    Hello!
    I am in the process of restoring my 73.5 911 Targa. While preparing for the paint job we noticed there was no felt in the rear window guide (the channel in the door, No. 2 in diagram).
    Can anyone confirm this is how it is supposed to be? I would have expected a similar rubber/felt guide as in front (No.3 in diagram).
    Name:  Targa window frame diagram.jpg
    Name:  IMG_9390 (768x1024).jpg
    Many thanks for the help!
    Ben
    Membership # 3518
    1973 911T Targa
    ben,
    there is definitely a seal in there, on the PET part number 91154290500 is x 2 per door.
    regards
    Craig
    Newcastle, Australia
    ESR #1479
    1973 2.4E Coupe ex Hong Kong ex Norfolk Island ex New Zealand now in Oz
    (Autowerks restored stunner)
    http://www.autowerks.com.au/porsche_projects/index.html
    1972 2.4E Targa ex Germany ex Japan now in Oz
    (another Autowerks project)
    1969 built E based Vintage Racer
    (another Autowerks beauty)
    http://s12.photobucket.com/?postlogin=true
    Jan 2017
    Houston, TX
    Thanks Craig, That's a good point. I had overlooked the "2" in the qty column.
    So I guess its a matter of ordering that part and cut it to length to fit on the rear side.
    Thanks much!
    Membership # 3518
    1973 911T Targa
    The outer rail (2 on the Pet image) holds the plastic section on the window rail. Ie the glass does not run in the channel like a coupe. It thus has no felt runner. The pet shows felt runner 3 as needing 2 of them, that means one for each door as they are not handed.
    HTH
    Alan
    As Alan says, bare brass:
    Jan 2017
    Houston, TX
    Thanks for the feedback and pictures folks!
    Membership # 3518
    1973 911T Targa
    looks like i am definitely wrong
    Craig
    ESR #1479
Tags for this Thread
