Thread: ground connections
    Jun 2011
    Bellingham, WA
    ground connections
    I am cleaning the ground connections. Where is (are) the ground connections for the dash area, gauges etc
    thanks Tom
    right behind the bottom mount of left hood strut.
    Jun 2011
    Bellingham, WA
    Thanks Ed I was able to reach in with just a few scrapes. I have cleaned the 4 for the turn signal clusters, the dashboard, the altenator strap & the transmission strap. also battery straps Are there any more?
    Quote Originally Posted by 72t4tom View Post
    LEFT side engine bay just forward of the MFI fuel canister housing there is another stud on the wheel housing where several brown ground wires attach. If your engine is installed, they will not be real visible...perhaps removing the air cleaner and 'diving in' as far as you can and then look left past the canister.
