Results 1 to 10 of 14
Thread: Unknown holes in luggage compartment
    A friend of mine has these 2 holes in the luggage compartment.
    They are just above the metal vin plate.
    I have marked them with a red circle.
    I did not see a lot of cars with these - does it where holes that came when you chose a option?
    Name:  Schermafbeelding 2017-03-05 om 17.54.38.jpg
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Michael Winters View Post
    webasto.....
    Franz,
    Thanks.
    Jacques (pss) was also wondering what these holes were on his car.
    Now he also has a answer.
    These 2 holes have both a tube that is coming out.
    Do they also have both a tube when you restored a webasto only as a blower like we talked before?
    What is also interested to see is that on the picture (pss) his car, there are 3 holes above each other.
    The 2 marked in red are for the webasto like you replied. But then there is also a hole next the the pipe that has a rubber tube over it.
    In this hole you see that there is going a cable in. Is this correct and where is this hole for?
    Because when you see on this picture there are 2 tubes marked in red.
    I also noticed that I did not have these 3 holes above eachother anymore.
    But since I had a webasto on my kardex, I suppose they closed them by welding?
    So need to provide this body panel of 3 holes (2 for webasto and 1 for....)
    Hi, all be it on a LWB car here is a petrol heater in my 72S.
    May 2013
    AUSTRIA (tu felix)
    the foremost is fuel tank to carb
    the center one is fresh air to carb
    the 3rd is air/fuel mix from carb to vac.pump
    Thanks!!!
    A wherefore is the metal L-shape tube with a rubber flexibel tube on the top for? See post 1
    This is also the one that is not on post 4.
    Happy to learn more...
    May 2013
    AUSTRIA (tu felix)
    Franz,
    as i told you several times already...no one will see a difference--cause there is no visible difference.
    May 2013
    AUSTRIA (tu felix)
    Thanks!!!
    drain tube from drip pan
    BTW
    the trunk area of your vehículo is quite a welding mess
    Feb 2013
    Europe
    BTW
    I thought the same. It will cost quite a bit of effort/money to solve that. Wow.
    You indeed told that the webasto-system under the webasto coverlid was same with the two functions.
    But I thought there was maybe one tube that was not needed anymore in case of blower. But no...
Tags for this Thread
