Results 1 to 10 of 15
Thread: FS: F/R factory sway bars (15mm)
    Complete set of F/R factory 15mm sway bars, $700 + shipping
    Still available
    Member sbartmess's Avatar
    Dec 2015
    NW Suburbs of Chicago
    What is the spacing measure between the rear sway bar bolt centers?
    Scott Bartmess - Mbr. No. 3344
    65 356C Cab
    67 911 Sunroof
    71 914-6
    18 991.2 GT3 Touring
    Seeking Engine Case No. 911867
    Quote Originally Posted by sbartmess View Post
    If I understand, it is 56mm.
    Can you provide all original attaching hardware?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    If your car was not factory equipped you can fit the front without modification. However the back will require some welding.
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    Still available, complete original set, except the 4 M8x40 bolt (front stab) and the 4 guide plates/M8x62 (front lever), $600+ shipping.
    Jul 2003
    Santa Cruz, CA
    Never before seen an original bar with a part number engraved (silkscreen?) like that. All of the original bars I've ever laid my mits on only had the size stamped in the bar end. Is this a later offering from Porsche classic?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Probably, and built by Eibach ;-)
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by damsroy View Post
    just in case
    http://www.early911sregistry.org/for...257#post893257
