Results 1 to 8 of 8
Thread: Steering wheel splines
    Aug 2010
    Colorado
    Will a 914 380 mm 4 spoke steering wheel fit on a 67 911/912?
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Jan 2007
    North of the GG Bridge
    Yes (stock VDO), with the modification to mount the horn cancel ring, if you want the horn to work. There may be a 100 threads here on this (perhaps I exaggerated ).
    Jul 2011
    Chicago Area
    No modifications if it is a 914-6 wheel. Dated pre '72 like a 806.10, 805.10 or a 803.10.
    Mike Fitton # 2071
    2018 911S Carrera White
    Feb 2016
    Sterling, Va
    I just removed a 914 wheel from 1973 (914.347.804.11) from my 912 that had been on the car for over 23 years and replaced it with a period correct wheel. It was a straight forward replacement.
    Steve
    Jul 2011
    Chicago Area
    Quote Originally Posted by stevesob View Post
    Steve
    Maybe so but it was modified to take the 912 cancel ring. The spline is not the issue, the rear plate needs 2 holes counter sunk to take the cancel ring.
    Mike Fitton # 2071
    Aug 2010
    Colorado
    The one I'm looking at is 914.347.809.00. It's fake leather, 1972 and later if I'm correct. I guess it will need to be drilled and taped.
    Chris
    www.reSeeWorks.com
    Aug 2009
    SF Bay Area
    Chris
    Spend the next hour or so going through this thread.
    http://www.early911sregistry.org/for...eels-THE-TRUTH
    Ciao
    Jim
    Aug 2010
    Colorado
    Thanks Jim
    www.reSeeWorks.com
