Results 1 to 9 of 9
Thread: 1969 hood latch?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    1969 hood latch?
    I have a 1969 911 that was converted to a 1974 impact bumper car in the 1980's.
    i am converted it back to 1969 and selling off the 1974 hood and fenders.
    Would this latch on the 1974 hood be correct for 1969?
    www.tcspeed.com
    Aug 2009
    SF Bay Area
    no................................
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    What Jim said ....
    See pixName:  image.jpg
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Apr 2012
    Simi Valley Ca
    I'd remove that little Hella light in the lower corner of the hood. There are two of those on a '69.
    Bob B
    Nov 2015
    Quote Originally Posted by SIMI BOB View Post
    Bob B
    thanks for the tip!
    www.tcspeed.com
    Two on a '69 911S...only one on right/passenger side on 912s, Ts and Es. Left side opening on the single light cars has a cardboard cover with plastic rivets.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Sep 2012
    Colorado
    No trunk light on my '69T, and no cover.
    Both my '69T and '69 912 had a single light.....if there's not a single, someone removed it. Check up in the right trunk/dash area behind the cardboard wiring cover...the wires will be there. What about the spring plunger switch on the right hinge?? I believe the owner's manual references the trunk light.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Apr 2012
    Simi Valley Ca
    Two lights on my '69 S. Exact same light used for a license plate light on my '66 bug. Probably others too. The Hella lenses are probably long gone.
    Bob B
