Results 1 to 5 of 5
Thread: RSR Racing Engine Oil Cooler Delete ?
    Have an 89 3.2 engine going up to a 3.4/single plug with hot cam and 9.8CR.
    I will have dual fender coolers up front.
    Question is do I need the on-engine cooler??? I've heard this may be more important/effective than front coolers especially 'in traffic' or moving slowly???
    What are advantages to removing?
    I've seen the RSR/Racing filters that can be put in place, but why did they do this??
    This is what would replace the oil cooler at the back of the engine.
    Name:  05022015150959oil filter assembly 3 800.jpg
    Feb 2011
    Northern VA
    You can also use the 964 piece... which is cheaper and available ... but not as cool
    They wanted a cleanable filter.
    Do did they not run any filter except for this one??
    Anyone have a problem removing the cooler at this location?? In terms of higher temps, or problems idling, or in traffic, etc.
    Run the dual setup and you'll never be hot.
    Early S Registry #235
    rgruppe #111
