Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 1969S options on a 1969T COA?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    The COA states that my car would have a 1969S instrument cluster and 1969S fuel tank.
    What would the S cluster look like compared to a T cluster and how can i tell if it is a S tank in the car?
    www.tcspeed.com
    Nov 2003
    Sydney
    TCS
    the 2 standard T gauges were from the left,a gas gauge and an unnumbered temp gauge
    The 2 S gauges were from left,a combi gas and oil level and a combi numbered oil temp and pressure gauge
    the standard gas tank for the T was a 62 litre with a road option of a larger tank - 80 litre(?)
    there were also race tanks available of 100/120 litres which usually had the fillers through the front lid
    picture of your tank ?
    HTH
    Dennis
    S Registry member 536
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I am wondering if they meant OIL tank not fuel tank. The 911S gauges have the oil level gauge which requires a sender on the oil tank. Didn't the base T with no oil level gauge have a oil tank with no sender?
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Nov 2015
    Here are the gauges in the car:
    www.tcspeed.com
    Aug 2009
    SF Bay Area
    This is just another example of a screwed up COA. It must be a translation issue with the person who translated the info on your Kardex. I have never seen a COA or Kardex with "911S Instrument panel and fuel tank". That makes no sense. Your car probably came with a "comfort package" or "appearance group". That consisted of the, aforementioned, "S" gauges, "S" trim on the bumpers and rocker panels, Gold lettering, tinted glass, upgraded carpet.
    Jim
    Nov 2015
    Quote Originally Posted by gulf908 View Post
    TCS
    HTH
    Dennis
    Thanks. it appears i have the S gauges!
    The tank is standard fill in the fender. might be larger capacity?
    www.tcspeed.com
    Jul 2006
    Switzerland
    You have a T, right?
    If it came w S upgrades and as Jim said, it had usually the comfort package.
    Check if it has S carpet, gold lettering 911T on rear decklid, S rubbers, S rocker panels too.
    Tinted glass was not included but an separate option.
    Registry member No.773
    Nov 2015
    Quote Originally Posted by 911T1971 View Post
    This is all that was left
    www.tcspeed.com
    Feb 2016
    San Clemente, CA
    Found near Mexico?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by tcsracing1 View Post
    It does still have "S" rocker mouldings
