Thread: 1969 dual battery boxes?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    I will be restoring a 69 tub, and will need to do work to the front pan.
    I assume i should maintain the dual battery boxes?
    Any special uses?
    www.tcspeed.com
    The transition to dual batteries with the LWB cars was a practical move from the cast iron bumper weights. Moving that necessary mass as far forward as practical helped balance the car. the hot rod guys often eliminate the right box for placement of an oil cooler.....keeping just a left battery or placing the battery in the smuggler's box, which moves that mass further to the rear..not helping balance.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Nov 2015
    i am installing elephant external oil lines therefore i might just remove the box.
    www.tcspeed.com
