Thread: 1969 only dash and speaker grille
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    This is a 1969 dash only dash. The speaker hole/grille has different dimensions than later 70-75 dash. Rather mounting tabs are also different. There is one crack next to the speaker grille hole. No warped.
    Grill is perfectly flat but has some blemishes due -i assume- to removing the grille with the dash in place using inappropriate tools.
    Also the foam is damaged on one side (can't see it from the top). I believe it won't affect the dash once in place with the edge under the windshield seal.
    SOLD
    92F2B490-315C-45E6-84B4-E3FF23515DD8.jpg6C02CA94-B866-4426-9ADC-5510A1B04DA8.jpg0D524DDB-4F52-4E02-A636-CA1B3FDD2E7F.jpg30D9DD7C-4CBF-43D5-9A02-16168B4FC916.jpgC44D0B36-1353-4CB7-B639-60FAB6237B17.jpgC708D266-3895-44AC-81DA-914FEBF4A962.jpg
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    Jun 2007
    Connecticut
    Still available. 1969 MY only.
    912 1966 - sold
    PM sent. Cheers.
