Results 1 to 2 of 2
Thread: Front oil cooler
    Sep 2008
    Auckland , New Zealand
    Front oil cooler
    re fender or front spoiler oil cooler , what is the required flow rate and pressure rate needed/wanted. must be a minimum not to effect the stock engine and a preferred when running uprated oil pumps.
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Banned
    Nov 2004
    Scottsdale, AZ
    John,
    Not trying to be a putz but if you're reproducing front Behr coolers wouldn't it be wise to do your own testing?
    Trusting an uninterested stranger's opinion sounds unwise with such a crucial part.
    I have an extra cooler that leaks and could probably be repaired if you destroy some fins; perfect donor for your purposes. 700 U.S. ducats buys it.
