Thread: Is this normal?
    Is this normal?
    One of my rear axle struts is missing a cap. Is this normal? Can a cap be purchased?
    My car is a 1968 911 USA model
    I have a feeling that it did not come that way from the factory. I don't see a part number for that. I did see a part for cap on the front control arms. I believe it is part # 900-040-008-01 would this fit on the rear?
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    That's just a large "Freeze plug." Yes, same type in front A arms, but wrong size. They are dished so that when they are struck in the center they expand for a tight fit. Engine builder suppliers,maybe McMaster might have them. You will probably have to buy oversize and have someone turn them down in a lathe.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    South Carolina
    People drill them out or pull them off to access the torsion bar which can get rusted tight. I've also seen people put a rubber cap over the end.
    Thanks, just ordered from McMaster
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
