Results 1 to 10 of 11
Thread: Trick Question for Parts Experts?
    I'm looking for the part number for the speed nuts that go on the rear of the tunnel that hold on the access cover for the shifter joint.
    TIA
    james
    I think I found the part number, but they may be NLA.
    james
    Apr 2008
    Virginia's Blue Ridge
    Belmetric has a good assortment of speed nuts. The tunnel cover uses 4.8's...
    https://www.belmetric.com/metric-speed-nuts-c-3_856
    Quote Originally Posted by Bill Simmeth View Post
    Unfortunately its not your typical speed nut. Its square and snaps in place.
    That's a salvage yard part...there's hundreds out there!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Quote Originally Posted by smedley View Post
    You are probably correct. Sonnon Porsche took my on-line order so lets see what happens.
    Feb 2012
    Edmonton
    Either of these will work, Porsche part # 999.591.329.01 or 999.591.329.02
    One is silver colour the other is gold colour, I forget which is which.
    Quote Originally Posted by jrbennett View Post
    Seems that the -01 is the only one available. Lets see what I get from Sonnon.
    Does it look like this
    Aug 2009
    SF Bay Area
    Not in Emeryville. Mark, I think you have swept up every one of those in the building.
    Jim
