Results 1 to 10 of 14
Thread: What is a 902/1 trans?
    I have a January build '66 911 (Solex carbs) that I am restoring. It has Transmission Number 227136 and is a 902/1. Since this car was a barn find and not drivable I haven't explored the transmission. Can anyone help me out with information on this?
    Thanks!
    '66 911 - Light Ivory | Early '66 with Solex Carbs
    '72 911T - Aubergine originally | now Bahia Red | "S" options | 2.2S P&C's
    Feb 2016
    Sterling, Va
    TWJ, are you certain of that Transmission Number? I don't see that number in any range in the Tech Spec book.
    Steve
    Oct 2008
    Burford, ON, Canada
    902/1 was a very popular transmission type. It was the original 912 5 speed in 1965, used for both 911 & 912 in 1966 from the same serial series, used for both 911 & 912 in 1967 from separate serial series, and again in 1968 for the 911. A F M S X gears with 7:31 pinion & ring. Probably a typo in your serial; 221 instead of 227.
    I have both the COA and the Kardex, they both agree with the 227136 number. ???
    So it's a 5 speed and not a 4 speed? I've seen information pointing to both. ???
    Nice "sort of short" ratio from the factory box. My '67 has one. A "Z" 5th would be nicer for the highway.
    Early S Registry #235
    rgruppe #111
    Oct 2008
    Burford, ON, Canada
    Sorry, you are correct part of series 221722 to 234001 for 1966.
    Just to double check:
    5 Speed or 4 Speed?
    Quote Originally Posted by TWJ View Post
    Just to double check: 5 Speed or 4 Speed?
    Yes, 902/1 is a 5-speed, as described by Dave. Not to be confused with 902/01, which is a 4-speed.
    The 227 serial range seems correct to me for a Jan/Feb 66 build date.
    Jon B.
    Vista, CA
    AHHHH, thanks for the clarification Jon! That's where my confusion was coming from.
    Nov 2002
    San Dimas, CA
    The transmissions are all listed in the little specification booklet. Here are a few ratios:
    Transmission Type number of gears 1st gear 2nd gear 3rd gear 4th gear 5th gear ring & pinion
    901/0 5 AA 2.83:1 GA 1.78:1 O 1.22:1 U 1.04:1 Y 0.82:1 4.43:1
    902/0 4 A 3.09:1 H 1.68:1 Q 1.13:1 X 0.86:1 4.43:1
    902/1 5 A 3.09:1 F 1.89:1 M 1.32:1 S 1.04:1 X 0.86:1 4.43:1
    902/01 4 A 3.09:1 H 1.68:1 Q 1.13:1 X 0.86:1 4.43:1
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
